Can’t connect to tablo tv via google chrome. My ios app works and apple tv. I have click the red x to delete and re-scan and it finds the tablo. Then I click connect and then it comes back to the same click connect screen. No syncing happens.
Since the computer is not at home, I use a vpn to get it synced then you don’t need the vpn. But this hasn’t work for a while. I updated the tablo firmware last week and it didn’t help.
It works with the ios app at home and away from home.
I am having the same problem with chrome not connecting. It finds the tablo, but when I click on connect, it just spins with “connecting…”. Sometimes a cancel button also shows. I have tried firefox, and it loads fine. I have cleared my cache, and cookies, and restarted, but still no go.
If it works fine in Firefox, this suggests there could be something going wrong with the Chrome environment. Do you have several add-ons enabled in Chrome? Any VPN’s running inside the browser?
