Getting m3u from Tablo 4th gen
Is this still possible? I bought a 4th gen tablo and used this to expose an m3u stream from the tablo tuner. If I try using that m3u file in xTeVe, I get a 503 error.
If I go to 192.168.1.5:8887 (the Tablo’s IP), I just get “Hello, world!”. The Tablo is working fine on the iOS app but I want to use it with Plex. Any suggestions?
Looks like this isn’t possible. Luckily I kept the receipt. Good luck Tablo, I’m switching to SiliconDust’s HDHomeRun
I don’t think Tablo ever advertised that the Gen 4 was directly compatible with Plex. Plex is a cool system, but for more advanced users. Gen 4, although it helps to be tech-savvy, is intended for the general consumer.
HDHR with Channel DVR will do the trick. But it takes some time and skill.
From what I understand, previous generations were capable of this weren’t they? So they deliberately removed that functionality
Maybe… It has become pretty clear that the Gen 4 is a completely different animal than was the Legacy version.
