Gen4 Library View
I’m really liking the latest Android App Library view. It shows Scheduled and All Recordings as separate entries - AND THEY WORK AS DESIGNED! This should be done across platforms. Too bad we don’t watch on our phone.
FireTV Stick 4k Max just shows All Recordings and is an undesirable configuration; would like to see the All Recordings split up here to add Scheduled:
Android phone app shows both Scheduled and All Recordings - very nice; similar to what’s in the OG Legacy app:
How big is your drive. I’m having problems playing shows from ALL CHANNELS if I have more than 200 episodes in a program. The recording will start and then crash. If I keep trying eventually it may play but after trying half a dozen times my wife has had enough. I noticed that most of the episodes icon/descriptions don’t even load on my Android phone. I’m using an onn 4k Pro with 2.1 TB on a 5 TB drive. We are just about ready to give up on this DVR and go back to our trusty TIVO.
I’ve been asking this for months. I end up looking at my phone to see what recordings are available to watch, then watch them on my TV.
Sorry you’re running into this problem. We use a 1 Tb WD drive and it’s usually not >50% full.
Tivo is trusty… I had Tivo for the longest time. Loved it. But to go back would dig really deep into my pocketbook. I have a 4TB WD with about 50% space left on it and so far so good.
I agree, feature parity between the two (and really all the 4th gen apps) would be nice.
