My gen 4 would loose live TV every few hours. Had all the latest software ( App, Tablo and Roku). Finally got it corrected. Disabled Roku “Screensaver” and “Bandwidth Saver”. Problem solved!
Thank you for that! I have been having the same disconnect issue, so I will try that. Tablo support never mentioned trying this when I have turned in a ticket for the issue.
Well, I had hoped that my problem was solved by doing this. I will say that it happens less frequently, but it still happens quite often.
