This happens about every 3 or 4 mths, and it takes forever to get my Tablo back up. Please help me trying to find a shortcut to my problem. I was watching tv through Tablo and it just froze, then it said there was no Tablo. So I reset the main router, as Tablo is run through wifi. I reset the Tablo by disconnecting the power. I reset the Tablo via the blue reset button, the short version and the long version, wiping out my recordings. The xfinity router has dchp enabled. The blue light is solid on the Tablo, after all the resets. I can access Tablo via my phone app. But when I turn on the app on the tv, it says no Tablo. I can view all the other apps on the tv ok. Why cannot I view Tablo on my tv and how do I fix it?
A post was merged into an existing topic: Almost time to set the Flintstones
I think @TabloTV Tablo merged this thread with an incorrect thread. Why merge with “Almost time to set the Flinstones” thread?
Someone accidentally added a reply to a different topic on this topic. Simply moved the reply post to the correct spot.
trying to repost in correct topic
