I’ve also seen the freezing issue at times when I fast forward. Exiting and entering the show seems to fix it, at least temporarily. Happens on all my Rokus, but it’s pretty infrequent, at least at this point.
06/05/22 - Ok, happening more frequently and another weird thing… sometimes if I press and hold the right side of the ‘cross’ on the remote, it won’t continue moving forward. And sometimes it will. I really believe Roku screwed this up as I have a similar issue on Youtube.
Since reporting a few issues with Tablo 14 days ago we have not had any during fast forwarding through commercials. Now as far as Roku goes it continues to do flaky things mostly with Youtube. It has always done this.
Try disabling “Auto power savings” in the Roku app: Settings > System > Power > Auto power savings = unchecked. Note that this may use a little more power.
In the “Settings” menu, under the heading / menu choice of “System”, I have 11 different options, but none of them is “Power” (or anything related to “Power”).
Perhaps older Roku models such as my eight year old Roku boxes, do not offer this option?
I have 2 smart TVs with Roku OS. In Roku Settings → System → Power there is an Auto Power Savings with 2 checkboxes. The first checkbox “Reduce power after 15 minutes” reduces power when the TV senses no activity after 15 minutes. I have it unchecked. The second checkbox “Turn off after 4 hours”, which turns the TV off if it senses no activity in 4 hours. I have it checked, but it is ignored because I have “Fast TV start” enabled.
Regardless, this has nothing to do with the Tablo box itself which does its recording on its own schedule and couldn’t care less what my Roku TV is doing. I suspect the spinning circle on fast forwarding when using the Tablo app has something to do with the recording itself. Some characteristic of the recording is causing the app to have problems when requesting a fast forward of the recording.
I don’t often watch live TV, so I don’t know if the spinning circle happens if I try to rewind or fast foward a live TV show I’m watching.
Not surprisingly, the recommendation to fix the freezing and crashing of Roku in the Tablo app by using the Network bandwidth toggle did not work whatsoever.
My freezing and crashing problem can still be provoked just as easily regardless of the setting of the bandwidth switch.
From a fresh start/reboot of the Roku, I can usually get a freeze in less than a minute or two, by fast forwarding on the time line. This scrubbing continues to be exactly the same problem I am still seeing on each Roku of the seven that I have here.
I highly doubt that anyone else will see any benefit from this recommendation whatsoever.
I am still hoping that Tablo will take ownership of addressing this issue, and, at the very minimum, reply to the post made by someone else earlier in this thread, asking them in Ottawa to PLEASE give us some indication as to what is being done here!!
This is a very ANNOYING, FRUSTRATING, FREQUENTLY OCCURRING problem, and needs to be addressed.
Roku is the market leader in set top boxes to say nothing of their TV sets with built-in Roku. We deserve to have a working Tablo app that does not crash and freeze.
Is this Roku freezing issue occuring only for users that have commercial skip option?
Asking, cuz I don’t have commercial skip, and don’t have this issue at all on 4 Rokus.
I can scrub (fast forward, reverse) at any speed, and no freezing.
If you have commercial skip option, and disable it, does the freezing still occur?
I have 3 TVs, and all 3 run on roku. I have seen the spinning circle obout 10 times in the last month. I just let it spin and after ~30-60 secs the show continues with no problems. We watch about 2-5 hrs of recorded content every day. I have NEVER seen this spinning wheel BEFORE the last roku update, so I assume THAT is the problem. Will report back after the next roku update.
When this freezing and crashing issue arose a few years ago with Tablo and Roku, with similar symptoms and the same method to provoke failure (scrubbing), there was no commercial skip. Most noteworthy is that ONLY SOME users had the problem, others didn’t. Same situation here.
That’s what bugs are all about. Why they affect some users and not others has everything to do with code which is exercised for some circumstances but not others, impacting some users but not others in the process .
Something as basic as network topology and error rates can explain this entirely. A heavily loaded network with frequent packet retries, or one which is heavily saturated at some times, may cause scrubbing to get deferred. My only point here is that each of us has different configurations in many ways, and truly correct bug free software handles these cases properly.
