It seems that Fox at least in my area has started pushing descriptive audio on many shows.
But there doesn’t seem to be a way to disable descriptive audio in the Table. Shows being recorded from Fox are playing with the descriptive audio which is really annoying.
Thanks for the info. If it continues to happen I do already have an iView tuner I could use to record my fox channel. It’s just it was the 1st time in 4 years we’ve had this issue.
