Good Day Everyone!
I received up a Tablo 4-Tuner unit from a family member for my birthday and I’ve been struggling to set it up since. I have searched several topics on the forums and I haven’t seen one that seems similar to my situation. Here’s my rundown of what I have tried and what happens each time.
Wired Connection: I initially tried connecting using an ethernet connection directly into the router. I’m able to see and attempt a connection to the Tablo using the Tablo App on my iPad. Whenever I click Connect it brings up the Retrieving Tablos… screen, then cycles back to the Connect to Tablo screen. I’m unable to see or connect to the Tablo using a web browser on any connected device. I’ve left it connected like this for several days with no changes. There is a solid blue light on the device.
WiFi Connection: Same end result as above. I connect to the WiFi network generated by the Tablo and I’m able to point it to my local network. I’m able to see it on the iPad using the App but I’m not able to secure a connection. Again a solid blue light on the device.
Mobile Connection: Same end result as above. Just to eliminate my router as a possible issue I created a hotspot with my phone and connected both the Tablo and my iPad to the hotspot. I’m again able to see the Tablo in the App but I’m stuck with the same “Retrieving Tablos…” message and a cycle back to the Connect to Tablo screen. Also a solid blue light on the device.
Resets: In testing all of the above scenarios I have rebooted the Tablo, router, iPad and computer all with the same result of being able to see the Tablo but not establish a connection.
I’m not sure what to try next, it’s very flustering to feel like I’m so close to being able to connect but getting stuck on this loop.
Has anyone else experienced this before?
Anything I should try that I haven’t yet?
Thank you!
