If I pause the Tablo long enough for the screen saver to come on then it really screws up the tablo, I basically have to delete and reconnect the tablo to get back to watching TV. Is there a setting or something I can change to fix this?
Sorry to hear you’re running into this.
What generation of Fire Stick are you using? And which version of the app? The original or the Preview app?
2nd generation fire stick and using the original tablo app
Thanks! We’ll take a closer look at this today. Stay tuned.
Staying tuned
