I have 2 fire TVs (one is a gen 1 and the other is a 4k box) and two Fire Stick devices and this happens on all of them.
while watching a show on the Tablo app I will get a screen that says that the device has changed addresses. If i go back to the guide/recorded screen and then back into the show it continues to operate.
There is absolutely no way that the Tablo is changing IP addresses as I have it set as a static IP in the router. Also, the Tablo and the 4k fire TV are hard wire into the network so I know it is not a WAN issue.
I also have an issue with the app just freezing during a show. I have to go all the way out and force stop the app to get it working right again. This also happens with the hard wire Fire TV but not as often.
Sorry to say , I have not seen this behavior with my 1st & 2nd gen Fire TV boxes.
I know you said the Tablo has an IP reservation from your router, Do the Fire TV’s have an IP reservation as well? Maybe that is what’s causing the problem. (I’m just throwing out ideas) I have reservations for all my electronics that need an IP.
Like @rccolts, when I got this error it was due to the hard drive. When I first got my Tablo, I decided to try and use an old hard drive I had laying around. Come to find out it was bad. Got a new one and haven’t seen the error since.
If you have a different usb cable for your hard drive, you can try that. I do remember having to switch out my usb cable that came with my hard drive with the one that came with my phone and had a better experience. Try that before you try a different hard drive. Not all usb cables are created equal.
