How do I find my Tablo’s up address? I just need to know what it is now. I don’t need to set one up manually on my router or anything.
Thanks
Thanks
see this thread: Wired vs wireless
If you are using iOS, try
Fing - Network Scanner by Domotz Ltd
Use a supported browser and go to http://my.tablotv.com/. Pick the settings tab from the top left corner menu. Scroll down to the “ABOUT” section. The IP address is labeled “Server Host”.
@FlyingDiver @tminor [quote=“FlyingDiver, post:4, topic:11584, full:true”]
[/quote]
This is the case for most of the Tablo apps (barring the iPad app). You should be able to find your Tablo’s local IP the Settings/About screen.
I thought that was the ip address, just wanted to make sure. But that iOS app is pretty cool. Thanks
My tablo’s ip address has changed. How do I get it back to the one it was? Or a different one. I realize now I need to set it up in my router. I need it to change, because it now has the same IP address as my printer and I can not print. Thanks
This sounds like an issue with your router. It should not assigning the same IP address to different devices.
