Favorite Channel option missing
The option to select a channel as a Favorite isn’t displayed. When I select a program from the guide, not the channel itself, I get the 4 options, Watch Live, Record Episode, Series Info and Select Series Recording. There is no ‘Add to Favorites’ option shown as in Tablo instructions. What am I missing? Thanks
Favoriting a channel is only available from the live grid.
There is no ‘Add to Favorites’ option shown.
Which app are you using?
Can you send a screenshot?
Are you using the LG or Samsung app?
If so, that option is not yet available on those platforms.
I am using the Tablo app on an LG TV. Which the Tablo descriptions mention as compatible.
Unfortunately compatible and identical are not the same thing in Tablo world.
