When using the Tablo Connect feature away from home there does not seem to be a quick way to fast forward through a recording to get to a point later on in a recording.
Say I’m watching a game recorded earlier that I happened to start watching live and then will finish watching remotely later on. I can pause and “scrub” forward a bit but must wait a long time for the recording to do some buffering before I can jump later into the recording. Using the 30 second skip also is not practical.
Also, as for an unrelated feature request, I know it has been mentioned before but having options for the 30 sec skip would be great. Perhaps a 1 min or 2 min selectable option or possibly just a long press where you get those options would be very welcomed.
