The only fast channel I watch regularly is Newsmax2. Over the last couple of months, I’ve noticed that it has skipped back in time on it’s own by 2 or 3 minutes. I found this out by observing commercials repeating. I fast forward to live and a while later it has done it again. Anyone else seeing this and can it be fixed?
Thanks
Hi @Scaleman, would you be able to let us know what Tablo app device you’re using and seeing this on? For example, Roku, Apple TV, Fire TV, etc.
I am using the Legacy Table with the latest rev. Gen 4 app on Amazon Fire Stick.
Thanks
Thank you.
Are you able to check any other FAST channel to see if the same thing happens elsewhere too? And also if possible if it happens on any OTA channels too?
I tried 3 other fast channels and did not see the same issue. I did not try any OTA channels.
I just tried the Johnny Carson channel it is now 56 seconds behind live.
So I tuned into Newsmax 2 about 30 minutes ago. I just checked and I am now over 3 minutes behind “live” air time. Has there been any progress on this issue? I believe it has something to do with the ION TV commercials repeating themselves to get maximum advertising dollars.
