Hello Community,
I started to ear a fan noise or buzzing noise from my Tablo 4gen.
It just have been on for 5 months.
Did someone ever had this problems ?
Thanks
Hello Community,
Thanks
I don’t believe that the Gen4 has any sort of internal fan. I would give a call to Tech Support.
There are no fans in our 4th Generation Tablo. Nothing should be spinning at all. It may be viable to double-check your external hard drive.
Maybe you’re hearing some coil whine, or possibly there is another nearby component making the noise?
The noise is getting worst and the blue light was flashing non stop. I had to unplug it.
It worked for one day and now I get video cannot be found in the library .
I did watched some shows last night.
You should contact Tablo support, maybe your unit has a problem.
Do you have a hard drive connected? If you do did you disconnect it to see what happens?
