I can play other recordings! I was watching the beginning of a couple games. Deleted the failed to record games due to weak signal. Could watch those live with a strong signal on tv. A previous help topic I sent a few days ago.
I’m going to record something today to see if it will load and play.
Wonder if the channel the games are on have weak signal?
Every tuner isnt built the same.
Thanks! I finally got it to work. Deleted the app and reinstalled it on my Apple TV device.
I don’t know how good the built in signal detection system is in my LG TV. It has an indicator for strength and quality. The strongest channel I can get is a tower 40 miles and VHF. The tv shows it to be 70-76 in strength. With 100% quality. I get 5 other channels from a translator tower. The RF for those are 18, 22, 26, 34, and 35. The signal strength from that tower is 68-72 with 100% quality.
I’m sure there are times when that tower isn’t receiving a quality signal even though it’s still responding and it looks like I’m receiving a strong signal from it. Because sometimes even my tv doesn’t get a picture or audio. With a 70 signal strength and 100% quality. Only from that tower, usually only one or two of the channels.
