Failed recording showing false number
Have 2 Tablos which after having the firmware update and updating the app is showing 127 failed recording even though there are no failed recording at all.
When failed recording is selected it will show “Unknown Error” with a retry and cancel button, on retry it will just circle back.
Have no issue recording or viewing channels but just wanted to mention it in case it will be an issue when there is really a failed recording in there.
The other thing that have notice but is not exclusive to this firmware or app version is that if a recording fails, it will show it in failed recording, will not be in latest (which is good) but in the guide it still shows the yellow band as if it is being recorded and if you click will have option to stop recording.
This again is more for info as if want to start the recording again can just stop the recording and start it after if updates.
But really if a recording fails it should reset the guide and latest in library to to match that the program is not longer recording.
This is all FYI, I will not contact support as they will have you do 100 steps (a lot of repeats) and still not be able to fix the issue, unless my Tablo is complete unusable due to something only Tablo can answer.
Quick reset? NOT full factory reset. If using external storage maybe that is corrupt?
Thank you.
Found that issue and it is coming from Tablo side but it might actually be Guide data issue which may not be something Tablo can do much about.
It happens cause of a program schedule to record on Sundays which for some reason will end up showing 127 upcoming even though if you look at upcoming there usually only two maybe three actual ones.
To clear it have to remove the program then re-add it, though it happen again for the next weeks upcoming program.
As long as it doesn’t break all recording and doesn’t stop the program it has the wrong number of upcoming still records don’t have an issue with it.
Thanks again.
