I can’t get my Tablo to connect remotely through my Peplink mini br1.
I can stream any other apps on the firestick, but not the tablo app.
I also can’t connect to tablo on my phone through the peplink.
Remotely as in outside of the WAN port? Through Peplink InTouch?
Is the Tablo hardwired in or wirelessly connected?
My Legacy Tablo is at my house hardwired to my Verizon Fios internet.
I have remote viewing set up, & can access on my phone via Verizon cell service anywhere.
I can also connect via firestick thru any other wifi except the peplink router, whether connecting via verizon sim card, or Starlink that is connected to the peplink via ethernet into the WAN port.
I can connect directly to the Starlink router via it’s wifi.
Your Peplink BR1 Mini might be blocking certain ports or not handling UPnP/NAT-PMP properly, which Tablo requires for remote access. Since your other apps work, the issue is likely with port forwarding or firewall settings. Try these steps:
Enable UPnP on your Peplink router (check under Network > UPnP/NAT-PMP).
Manually forward ports required by Tablo (check Tablo’s network settings for the specific ports).
Check firewall rules to ensure nothing is blocking Tablo’s traffic.
Restart both your Tablo and Peplink router after making changes.
For a deeper dive into router configurations and Verizon-compatible networking solutions, check out https://www.fiosgateway.org/ you might find some helpful tips there!
