Factory reset question
how tuff was it to get everything back up and running
It’s not hard at all. If you reset your tablo your going to lose your recording but you might still see them but when the guiros updated that night around 2am it should clean up the recording to what you have recorded. Hope that helps
Thanks,I will try it!!!
