Is the external USB drive supposed to blink lights and spin 24/7 even when tablo us not in use? Just wondering if it will have a short life span running all the time. I have a Toshiba casino connect,
Thanks.
Darren
Thanks.
Darren
There shouldn’t be drive access but yes, spin 24/7.Â
Hard drives fail, some more than others.  Most commercials DVRs use drives optimized for video use, not standard consumer desktop drives.   If this is of concern you can definitely use a hard drive optimized for video use with Tablo which is what I’m doing
True - but I would expect drives used with DVR would experience less fragmentation and thus less head seeking. I note that when recording and viewing the drive with my Tablo is barely moving, the LEDs hardly flash - compared to starting Windows, opening Word, saving a document, etc. I’d expect drives for video to be less taxed in that the heads don’t slam around as much.Â
I have read that the power on/off cycle is a contributing factor to drive failure. Â Unless you never delete any episodes, there is going to be fragmentation.
Thanks, I tweeted @tablotv this question and they said drive shouldn’t spin when table isn’t playing content or recording. Thanks for your response.
I like my tablo but that’s a rather crazy answer. Some drives have a sleep timer and some do not and depend on the host(tablo) to be put into sleep mode. So for drives that have sleep timers just what does tablo support state is the desired sleep settings. And for those that are controlled by the host(tablo) how long does tablo take to put the drive in sleep mode? Additionally does tablo keep log files on the drive? If so how often are these updated and just what events cause these to be updated?
After getting my 2-tuner Tablo (back in May) my Seagate Backup Plus Slim USB HD would never spin down. I resorted to downloading a software tool from Seagate, and set the sleep time to 10 mins. Has been working without problems, most of the time the drive is sleeping.
The problem with turning on sleep on hard drives is that the Tablo cannot wake them back up. It can with some drives but not all. Hence the suggestion to turn off sleep mode on drives attached to the Tablo.
I am also worried about the 24/7 aspect with regards to hard drive usage. I use Roku to view and make sure that I exit the Tablo app before turning off the TV otherwise the Tablo will be recording (buffering) whatever live TV I was watching all night long. Just remember that if something is streaming live TV your hard drive is in constant use. As for fragmentation; that shouldn’t be an issue due to the static file system created in “blocks” on any DVR system. Your show isn’t one giant 2Gb file, its comprised of a huge pile of 10 second clips that are played back to back to display the show. The “clips” is the main reason you can’t just download files from your Tablo to your PC.
I used to work in an electronic engineering firm. The QA person there was keen to remind folks that electronics fail at power-up and that was a fact.
This is all wonderful, that having the drive on and off could be worse, but doesn’t answer, why is my hard drive running 24/7 on my Tablo? Does that mean that it’s supposed to be spinning all day, all night? And about the computers, the drives go to sleep.
I want to go off a little at the same time. Can I use a SSD on the Tablo or is there something that would make that a bad choice? I’m asking because, there aren’t motors or heads or anything. But I also read that a memory stick or SD or CF Etc. is not recommended.
I’m happy with my USB 3 hard drive, USB 2 wouldn’t be recognized or format. Fine, welcome to the modern world.
USB keys or sticks aren’t recommended cause many are too slow or their read and write life are too short.
SSDs do not suffer from either of those problems, so while it is likely overkill to use an SSD with a Tablo, go ahead.
I am using a 2tb WD SSD (internal in Tablo Quad), no issues. Downside of an SSD is cost, regular hard drives are much cheaper. Also, in my experience SSDs run hotter than a regular drive. Regular hard drives may have a way to set a sleep time in the drive. I had a Seagate USB2 drive that I used with a 10 minute sleep setting, ran great for years. Most times if I went to the Tablo the drive would not be spinning.
