I have activated Remote Access and done the settings on my router. No problem there. But I cannot get Remote access to work.
I am using web interface and the app. I have two wifi networks (home and guest) to test out the remote access. All the mobile apps and web interfaces work when using the home network. It never works when using the guest network for remote access.
The Tablo documentation says I just need to connect to Tablo via the apps or the web interface, and then it should connect on an other network. This isn’t working.
What else can I try?
My screenshots below:
Remote Access has been set up.
