This error will show when you’re trying to do more things than you have available tuners.
So if you’re watching live TV and two recordings kick in on a 2-Tuner, we will ‘steal’ that tuner for the recording.
This is normal IF you indeed had multiple things on the go.
However, this is concerning since that is not expected behavior.
We have seen a few other folks report some odd behavior with the latest Roku update on older devices with lower memory. If you have some apps on your Roku that you use less often, can you try deleting them temporarily to see if something changes?
