No matter how many times, I edit (by either adding, removing or both) channels in my channel lineup in settings and then save, it is never - NEVER - accurate. It’s maddening. Thankfully it’s a small matter in ones life. But why can something so simple never work? Has anyone else experienced this?
Hi @Kolchak65,
What modle of Tablo are you using and which kind of Tablo device are you using it with?
Regardless, try clearing your app cache and then changing your channel lineup again.
I cleared cache, and I was able to get it in two tries. Thank you.
Happy to help @Kolchak65 !
