I had had my Tablo for 2 weeks and I select to record the entire series for multiple shows without duplicates. I am guessing that when a show is already recorded and it is showing again on live tv that Tablo will record the next scheduled show ( different show not the same ) that has not been recorded, is this correct?
When going through my recordings I noticed lots of duplicates.
Using my laptop, I click on each duplicate episode and noticed some are 2 minutes, others are 30 seconds, etc.
Feature Request: Please provide the recording time outside the episode on the main screen where you can see each episode. Please provide a checkbox next to each episode that way instead of clicking on each episode and deleting each one at a time I would be able to select the checkbox and then on delete selected.
Thank you…JGM
