Looks like the 64GB refurbish ($99) is cheaper than the LITE now.
Aside from the obvious storage difference between the two model, I noticed the wifi connection standard is also different.
If distance is a concern between the Tablo and your wifi router, which wifi standard is better for tablo? AC or N? Or does it make any difference?
Also what other difference between these two models.
New in Tablo.
