Two years ago, I got my parents a Tablo Dual, and a MyBook drive to go with it.
Over the weekend, they were no longer able to access the Tablo. I do not recall the status of the Tablo LED, but the drive LED was flashing fairly quickly, and I could hear it making typical hard drive noises, nothing unusual.
After a day of this, I pulled the plug, and restarted the Tablo. It did the same thing.
After a second day, I just disconnected the drive and took it to my place to see what my computer would do with it. It appears to be a perfectly normal, functioning, hard drive.
Folders at the root level are:
- del
- lost+found
- rec
- tmp
And files at the root level are:
- .nuvyyo
- .wake
Is there anything further that can be done to restore TV function? Are the recordings lost? (I suppose I can copy them locally, but I want my parents to be able to watch them via their Kodi Tablo app as usual).
