Swapped routers, different IP for devices, changed 0 to 1 to keep things separate.
Have 2 tablos, no issues connecting with one the second, fusses about internet connection. No flashing light, responds to pings. Using the discovery URL mentioned in the old days
https://api.tablotv.com/assocserver/getipinfo/
"cpes": [
"http": 21080,
"public_ip": "XXX.XXX.XXX.XXX",
"ssl": 0,
"host": "giv",
"private_ip": "192.168.1.100",
"slip": 21087,
"serverid": "SID_XXXXXXXXXXXX",
"inserted": "2020-12-12 13:50:27.349319+00:00",
"server_version": "2.2.30rc2017417",
"name": "tablo0",
"modified": "2020-12-31 17:25:30.857170+00:00",
"roku": 0,
"board": "giv",
"last_seen": "2020-12-31 17:25:30.838873+00:00"
"http": 21900,
"ssl": 0,
"host": "gii",
"private_ip": "192.168.0.21",
"slip": 21901,
"inserted": "2019-10-24 22:52:32.579047+00:00",
"name": "tablo2",
"modified": "2020-12-31 14:24:58.002975+00:00",
"roku": 0,
"board": "gii",
"last_seen": "2020-12-31 14:24:57.980200+00:00"
"success": true
One tablo has 192.168.1.X while the second still shows 0 – what’s up with that? I know, I can go and reboot it and likely it’ll update it’s self. Thing is, I didn’t reboot the first one, so again, why won’t it update it’s self since it lost it’s network connection?
Since a it’s unclear weather a recording is in process, to just randomly reboot my tablo isn’t always the best. If one device knows, both running the exact firmware, why?
Note, with 3rd party app where I enter an IP, I can access just like it has the network connection it has, just tablo server doesn’t have the updated information.
One will / One won’t …seems screwy. One of those “it’s a bug” and should be easy to fix, since the fist one did it.
Instead of rebooting, and risk a recording, I’m going to wait it out, see if it figures it out… or would someone have to wait until it updates / maintenance mode.
