How do I load the Legacy Table TV app on the new DirecTV Gemini box?
That wouldn’t be supported by the Tablo.
Nevermind, I figured it out. Login into the Google Play Store from your laptop on the same network as the TabloTV, Go to Apps, find the Legacy Tablo App, Install on other Device, Select your Gemini box, and wait a few minutes for the download.
Go into your Gemini box, Settings, Manage your Apps, and it should be there to open. Works great.
Cool. Didn’t realize it was also a GoogleTv device.
