Yesterday I noticed a programmed recording did not record. When viewing that it displayed a message that the signal was weak. So I just assumed the station was weak during that period. That same program is set to record every morning at 9 am. Well today it didn’t record either and gave the same message. So I decided to check things out.
Sure enough nothing is picked up by my Tablo Quad. I began swapping antenna cables around between the tv and Tablo. The Tablo is connected via a 2-way splitter that splits the antenna signal between the tv and Tablo. So I removed the splitter and connected the RG-6 that was going to the tv just to be sure.
TV antenna signals work fine. Tablo Quad just shows weak signal or if I attempt a Rescan it displays No Channels Found.
The Tablo itself still works with current recordings however. Just doesn’t seem to pick up anymore antenna signals.
How should I proceed?
Edit to update: After I posted the above I decided I probably should do a reset and/or a power down/power up cycle. Reset did not help however sure enough the power cycling(pulling the power cord) seemed to have fixed the issue. Keeping my fingers crossed.
