I have a 4-Tuner Legacy Tablo Device. For years, I could reliably watch Tablo via different computers and mobile devices, than more than year or two ago, things changed. Tablo connectivity only worked reliably from my Windows 11 Box. Success on smart phones using the Legacy Tablo app was very, very rare and always very temporary. I never could spot a pattern in these many failures and rare temporary successes I blamed this on Tablo itself for not supporting their Legacy device properly, but now, after a recent success, I am not so sure where the blame was. Quite likely, the problem had nothing to do with Tablo. Very likely, the problem was elsewhere.
How did I find this solution?
I recently solved a sporadic connection problem with an ancient but incredibly reliable Brother printer by assigning it a static IP address. Before this change, only my Windows 11 Box could find this printer, but Windows 11 is well known to be highly aggressive in finding devices, and many devices work harder to be discovered by Windows 11 computers. So all my other devices - several MacBooks and many Chromebooks - could never find that printer, much less print to it. Assigning a static IP address to that printer solved those connectivity problems.
With that success, I wondered if assigning a static IP address to my Legacy Tablo device would help? I was disappointed to find that Tablo does not support assigning a static IP address to its device. Then I learned I could still get an equivalent effect by using a DHCP Reservation using a MAC address to assign what is effectively a static IP address to my Tablo. I made a DHCP Reservation for my Legacy Tablo on my router.
Bingo!
It has been 10 days since that change, and I have now been able to watch Tablo using the Legacy Tablo app on all my mobile phone devices. Everything has been working perfectly. It even works on ChromeBooks, I believe, though by this I mean it works via the Legacy Tablo app - not the Chrome browser. It also works via the FireFox app.
Note: on some routers, it can be tricky to find your way to where DHCP Reservations are made.
For me on a Velops router from LinkSys, it took a fair bit of trial and error (with quite a lot of error) before I stumbled on to how to navigate to DHCP Reservations.
Also note that my DHCP lease was for a day, not an uncommon duration for a lease.. So I did not have some weirdly short lease duration. Nonetheless, I had terrible connection problems to my Legacy Tablo until I gave my Legacy Tablo (effectively) a static IP address through a DHCP Reservation.
So if you are having problems with your Legacy Tablo app connecting to your Legacy Tablo, try a DHCP Reservation. Your connectivity problems may go away.
NOTE: troubleshooting tips from Tablo do COVER this: DHCP Reservation, kind of
If Tablo Connect suddenly stops working, your router may be assigning a new IP address to your Tablo which would cause the port forwarding rules to stop working. Assigning a DHCP reservation to the Tablo will prevent this from happening.
I think (??) they wrote this in respect to watching your Tablo remotely when you are not at home, but travelling etc. Turns out that this advice also applies when you are trying to watch a Legacy Tablo from other devices on your local wi-fi. Certainly when I contacted Tablo with my local connectivity problems, they never told me to make a DHCP reservation for my Legacy Tablo.
