After the 2.2.18 firmware upgrade I started noticing programs, which were indicated as recorded, couldn’t be found. I contacted support and they did a manual fix to my tablo which temporarily cured the problem. I was told not to delete any shows I have watched until the new firmware 2.2.20 comes out. It was been months, my hard drive is filling up fast and will soon be full. I have having to curtail what I record to save space, but it is now May and no one has a delivery date for the 2.2.20 upgrade. I’m sure there are others out there with the same problem.
Is there some way that I could either revert to the old firmware or have a patch installed on my Tablo so that I could get rid of the massive load of undeleted programs? The situation will be getting desperate soon.
