Delete the schedule when a series stops airing
I’ll start by saying I have 2 gen 4 Tablos running simultaneously and I love them!
So I was recording a tv series, and viewing them as they recorded. Now the series has stopped airing, with no future airings coming. I have no recordings left, BUT the series Icon is still in the “library” of recordings, and I can’t remove it because I can’t find a way to remove.
Am I simply missing something? Is there a trick to it? I can’t get to “recording options”.
And using a TiVo 4k Stream device with the Tablo app on it, on a Samsung tv.
Thank you!
Did you change the recoding option to none?
I certainly would do that if I could, but i can’t reach that option. It only allows me to see scheduled recordings and of course that is none.
Assuming that it is a tv show:
From librsry
Select Tv Shows
Select the troublesome thumbnail
Select Recording Options above
Select Record and change from All Episodes to None.
This should work if I understand your explanation of the problem
Well, mission accomplished!
I went …
Library / tv shows / selected the program icon / went to “about” and from THERE I was able to get to recording options!
I picked none, and bam. I was good to go.
Thank you, you got me on the right path!
DLJ - glad it wasn’t just me… Had the same question/issue… Took me forever to figure out to go through the “About” button and then over and up…
Seems it takes more than it should, but I’m just glad there’s a way to do it…
Thanks..
This works on Roku and Firestick Tablo app but not on iOS/iPadOS 18 app. On iOS/iPadOS TV Shows does not show ‘dead’ shows.
Same problem, can’t delete a series that is scheduled in the app. Latest app & firmware.
Hi @sjoeg,
Would you be able to share with us some screen captures of what specifically is happening?
I believe I found the “user error”. Sorry for the alarm.
Thanks Joe
