Is there any tool or procedures for an end user to try to repair the Tablo database? I have been trying to pull off episodes of the Simpsons I had recorded earlier in the year.
I had set up to record all episodes so I have for instance season 14. 14-02 and 14-03 come down fine (using FFMEPG, basically what Tablo Ripper is using). Then 14-04 to 14-16 all fail.
They also do not play in Roku, Chrome, Android app, though they show up fine in the guides.
I’m wondering if there;s any way to rebuild indexes or if freeing up space or other things might make these recordings work again.
Do these episodes play on any device?
Have you tried Tablo Exporter by Jestep?
They don’t play on any device I have, iPhone, Roku 3, Chrome, Andrriod app.
Tablo Exporter uses ffmepg too, so I don’t think that would make any difference.
I used SurLaTablo to pulll out the filenames/numbers and just built the FFMPEG commands as a batch file.
ffmpeg.exe -y -i http://192.168.1.148:18080/pvr/64175/pl/playlist.m3u8 -codec copy -strict -2 -c:a aac -threads 0 “C:\MCEInput\tmp\The Simpsons - s14e04 - Large Marge.mp4”
I get
http://192.168.1.148:18080/pvr/76898/pl/playlist.m3u8: Invalid data found when processing input
