I am able to export a single *.ts file of program recordings from my TABLO using the TABLO-VLC add-in. Such files seem to play OK on various media players. However, I have not had very good luck making DVDs from these files. The videos do play, but seem to have a lot of interlace artifacts.
So my questions are:
01). Is there a preferred video setting in the TABLO that would have the best chance of yielding a DVD-compatible video file? (480i, 720P, 1080P, 30 or 60 fps)?
02). Should the TABLO-VLC program convert the files as it downloads instead of exportng the “raw” format, and, if so, what would be the best conversion routine to create a DVD-compatible file?
02). Has anyone found a good (read:FREE) DVD creator program that works with TABLO files?
Thanks for any suggestions.
