Al of a sudden Tablo stop working…Tried resetting but could not connect to internet…what is next option?
If you can no longer connect to your Tablo, your first step should be rebooting both your Tablo and your router.
If that doesn’t work, log into your router and see if the Tablo is even connected to your network. If it isn’t, maybe the network port went bad. If it is there, see if you can connect with other devices.
You can always submit a trouble ticket as well.
Thanks Snowcat…rebooting router worked!
