For some time now, our Tablo quad, purchased in 2017 has been having issues receiving a consistent signal on various channels we regularly record or watch live TV on. The problem started out as an infrequent annoyance, but now happens a lot, making many shows unwatchable. It is intermittent and comes and goes and I have not been able to tie the changes to weather or anything noticeable.
The DVR and live TV used to work nearly flawlessly, but that has all changed as of about 6 months ago or so.
Most times, it seems the OTA signal must be getting lost, and the result is the live feed video acts like its buffering, but its really just awaiting more video data which doesn’t exist, and frequently terminates and displays the blue screen with “Timeout waiting for video data.” If watching a recording, the recording may freeze video, and continue with audio, or display the buffering wheel with a frozen screen. If you fast forward or pause sometimes its jumps backward minutes and replays the previous few minutes of the recording, only to get hung up at the same spot again.
I have rebooted everything (router, modem, Tablo, etc.) multiple times when this happens - no affect. I have unplugged the hard drive and watched TV live without the hard drive attached - the issue still occurs. I do not believe this is a hard drive issue. WiFi signal is strong, 5 GHz band, and the WAP is within 10-15 feet on the same level as most receiving devices . I can stream 4K Netflix or Amazon Prime movies to a single TV with no issue in data transfer speed or buffering. We use Fire Sticks to receive the video from the Tablo and it is an issue with both the standard and 4K Fire Sticks, as well as with my iPhone.
I am certain this is not a “true” reception issue, but an issue created by the Tablo. I have tried a 5G/LTE filter in the coax line to the Tablo - no change. There is no cell tower within miles of our house anyways. I have an outdoor antenna, a RCA Compact Yagi VHF/UHF that is listed as having a 75 mile range, mounted about 12 feet above grade. The coax cable length from the antenna to the Tablo is maybe 30 feet, give or take. All the broadcast towers are between 24-29 miles away, all in the same direction - 183 and 185 degrees, and are virtually line of site (except for some trees). I can see the towers at night from the highway about an 1/8 mile from my house.
I have connected a cheap indoor antenna directly to my TV and I get great signal with the cheap antenna inside. I tired the cheap antenna on the Tablo and we still had the same issues with live TV and recordings.
The Tablo has the latest Firmware update ver. 2.2.42, but this was an issue with the previous firmware versions anyways.
The Tablo does sit right next to my router/WAP, so maybe that’s the issue? I would not think the router would interfere with the Tablo.
I have run out of things to check. My only conclusion is that the receiver in the Tablo is going bad. Any thoughts or suggestions would be welcome. Sorry for the long post and thank you.
