After a reset the unit works fine. The next day
the unit will not connect
I must reset the unit to get it working
This happens all the time
Many times the same day
bobk
bobk
You didn’t say what device you are using to connect. Or if you have tried other methods/apps to connect.
One guess would be that your DHCP server, usually a router, is feeding the tablo device a different IP address every 24 hours.
I have a dual lite. After a reset the unit operates for a few hours and than fails.
I do not have a subscription.
thanks for your reply
bobk
