Connecting ro 2nd tv via fire stick
My 4th generation tablo works fine on my Firestick in my tv in the living room. However, the second tv in another room keeps getting the error can’t find the device. I have to reset the modem and unplug the tablo. It comes back on but the problem keeps occurring, what can I do. It is also a rebuilt tablo that I bought from Walmart 2 weeks ago,
I might check all are on same wifi and frequency. Does phone connect correctly?
I’m they are both in the same frequency and internet speed is good. I use Google next extenders if that make a difference. The phone connect with. I problem
You might have multiple DHCP Servers providing dynamic IP addresses, which will cause issues.
You have a main router, which should have DHCP Server enabled.
You have network extenders, which should have DHCP Server disabled.
I experienced this with TP-Link network extenders.
DHCP Server is enabled, by default.
Why TP-Link, why?
I believe I read that the newest version of Firestick runs a new os that is not compatible with the current Tablo app.
Tablo has to release a new Firestick app to fix what they Amazon broke while maintaining compatability with the older sticks.
It helps to put model numbers of everything in the post.
It’s working now I rebooted the e finite router and it works fire stick 4k max 2nd generation
