I’m Dan & having difficulty connecting the android app with my 4th generation tablo over wifi. I’ve done everything the Tablo site suggested & nothing works. A couple of weeks ago I replaced my old phone with a Moto G play 2023. Not sure if that has anything to do with the problem. Thanks
Go ahead and download the WiFi Analyzer APP on your android phone. It will show you the signal strength of your wifi where you sit. Stand next to the Tablo and see whats the signal is.
anything above -73 is the start of low signal. You want me to be in the -40’s to -60’s range. If your wireless router is right next to the Tablo, it can be “too hot”, give it some space.
This is a good to start to confirming how your wifi splashing in your home.
So I’ve been using the Tablo for 6-7 months now and the one thing I have learned, not just recently but many years ago. You NEED a good router that’s properly setup. Most people who have internet issues most of the time, they are using the provided router with their ISP (internet company) and that equipment just isn’t good these days. Basically, they don’t handle multiple connections very good so devices like the Tablo will have connection issues.
I would say get a good WiFi 6 or 7 router from most anybody. If it has antennas sticking out of it tends to be an indication it’s decent (not always) I personally like asus routers. I have an RT AX58U and RT AX56U and the Tablo has been great on WiFi using those.
But the one thing I would suggest, most routers have this feature called Smart Connect that’s auto enabled out of the box. It basically combines the two radio bands, the 2.4 and 5ghz channels into one, where the router decides for you what channel to use. And quite frankly, they all suck at making that decision. So you end up getting too many devices on one frequency and then your router is maxed out and can’t work properly anymore.
Hopefully that makes sense. As someone else mentioned. Learning what channel your router is set to can have an impact on the Tablo, most routers are set to auto, channel 1,6 or 12. And if you’re in a busy neighborhood and everybody is on channel 6 for example, that can cause all sorts of connection issues. So you would need a special piece of software that would tell you what your neighbor‘s Wi-Fi routers are set to, on a Windows PC, under the App Store, there is an app called Wi-Fi analyzer, that will tell you what your neighbors 2.4ghz WiFi channels are.
Of course this requires know how, of how to connect to the administrator level of your router and making changes. It’s never simple unfortunately. But thanks to YouTube videos, looking up your routers model number, ChatGPT or Gemini, you can get to a point where you can open up the taps on your router. Or realize you need a better router in the first place.
I hope this helps.
Yep. You’ve touched on an assumption that many people make about their home network. A little bit of research can go a long way. One great idea is to use your favorite Chat Bot and put in your ISP and speed, router model number, and how the Tablo and streaming stick(s) are connected (wired or Wifi) and let the bot spit out a good starting scenario for your network configuration.
And sometimes wired can be a bad situation depending on the router. Some routers are still doing 10/100 these days and that will cripple a Tablo really hard
Tablo has a 100Mbps ethernet port. This is more than enough bandwidth for the Tablo’s max streaming capacity. A single 1080i mpeg-2 stream from the Tablo is around 8-12 Mbps according to my network performance monitoring. I doubt the Tablo would ever surpass 50Mbps streaming 4 programs at once.
Wifi may achieve bandwidth higher than 100Mbps under the right circumstances, but I don’t believe the Tablo would ever need or use it. Connection reliability is far more important to Tablo performance and reliability than more bandwidth in excess of 100Mbps. That’s why mine is hardwired (as are all of my smart TV devices).
Of course, 10Mbps would not cut it if that’s all someone’s ancient router could manage.
After downloading a couple of different wifi scanners, the app somehow began working with no issues. Thanks for the suggestions.
I just learned this recently on some Roku tv devices that when connected to Ethernet it was down to a crawl of like 2-5mbps. Back to WiFi and it was 70-100mbps. Every device does things differently including ones that say they are what they are but they don’t perform as good. So if someone is having issues with their tablo, it’s always going back to the WiFi router most of the time.
What exactly are you saying?
I’ll give you an example. If your router is an old netgear N600 from 15 years ago, that’s not a good router for tablo.
Modern house holds, lets say you and your significant other, you both have a smart phone, at least one of you has a tablet, you have at least two smart TVs, a couple smart cameras, a couple smart plugs. Half of that alone would cripple the old Netgear.
Most modern routers have features like MU-MIMO and OFDMA, which allows your router to basically handle multiple connections at once.
Basically if you’re running a very basic router, it’s basically playing pass the baton to every device one at a time, and that can lead to latency, connection dropoffs, lag etc.
I’ve been using an asus RT AX56U until recently I just upgraded to the AX58U. And we have 20+ devices here in our house. And never had any slow downs or hiccups worth talking about. But I know people who I do video conferencing with every week, who struggle to have a decent connection because of the WiFi router they are renting from their internet provider and it’s a piece of junk that doesn’t have those fancy features that allows multiple connections.
Another thing to pay attention to.
Make sure your router has the 2.4ghz 5ghz channel separated. Meaning. Let’s say, when you search for Wi-Fi networks, and you see your let’s say it says Netgear03, make sure there’s a second one called Netgear03_5G.
The 5G meaning the 5ghz channel. And just connect half of your devices to the 5ghz channel that make sense to use. It’s the faster connection but it also alleviate traffic from the 2.4ghz, which is what the tablo uses. You don’t want all of your WiFi devices exclusively on 2.4ghz. Unless you have a crazy high-end Wi-Fi 7 router that can handle tons of traffic on just that one channel, I would split the traffic between the two as much as possible.
That will prevent lag, latency, random connection drops as much as possible. I hope that helps.
Hard wiring Tablo to router(ethernet port) is always the best and most reliable connection.
100%, except for when it’s not possible.
My previous home was a two story 4 bed house with tvs and computers in each, and I had success using powerline adapters.
Interesting. I’ve heard of coax cable run adapters but not these.
They work best on houses built after ~2010 or so. Also, if you have 2 phase service make sure they are on the same one.
Ahh. That wouldn’t work in my house unfortunately. Thankfully my house weirdly was wired for the old cat5 cable for the phone lines and I ended up switching a few of those out for Ethernet a while back.
A coworker bought a 1920s house and was having a devil of a time because the walls were plastered using chicken wire. The house was in pristine condition with great wood trim, so he didn’t want to tear everything down and replace it.
So, he figured out where he wanted everthing, VERY CAREFULLY pulled the baseboard, and routed a channel in it for the ethernet. When he needed to go from room to room, he just poked a hole in the wall behind the baseboard.
It took some work, but when he was done, it looked like he never touched it
Wow. He basically lived in a faraday cage
Yep, plus each room was an individual one. He had to get passthrough antennas in the most used rooms so he could get cell service inside the house.
Check whether the Moto G Play is actually on the same Wi-Fi network as the Tablo, especially if your router has separate 2.4/5 GHz or guest networks. Also make sure the Tablo app has permission to access nearby devices/local network. As it worked with the old phone, try rebooting the phone and Tablo, then reinstall the app and reconnect while both are on the same main Wi-Fi. If it still doesn’t find the Tablo, temporarily disable any VPN or private DNS on the phone.
