For those of us who are not hearing impaired… read this.
Hi, Fred. Here is the link to the manual. http://support.tablotv.com/hc/en-us/sections/200374776-Tablo-User-Guide
@Fred - Yes, sorry we don’t have any documentation about CC yet… We’re trying to get caught up on that :)
And, if you pull your vids off the Tablo (e.g. using SurLaTablo), they contain the CC info, either embedded raw into the .ts or as subtitles when .mp4 (the latter requires you to use the optional ccextractor program and -C option).
As usual, Snowcat is correct. We do have CC enabled on Roku and on the iPad app. Hopefully one of these viewing methods will work for you and your family.
@TabloTV Is CC coming to the new Fire TV app?
@ChrisFix - We’re working on iroining out some of the technical details but it should be possible.
Anyway to permanently disable CC on the ROKU when you use the instant replay button… ? I notice it gets inadverntaly activated when you do… which is annoying (more so since its often gibberish)
Yes, @ericgus, on the Roku go into settings / captions / turn it off
Thank you!
I watch via Nvidia Shield and the Tablo USB tuner…any idea when you will have closed captions via the tuner? It is very difficult for people with a hearing problem to understand the words which I why I like it on Sling and Hulu, and Netflix.
Just keep holding the Select/OK button for a few seconds and you will get a CC prompt, then click Select/OK again to activate the option.
Did that - and still no Closed Captioning.
You need to hold the button while there is something playing (live TV or recordings). Did you not get the CC prompt after holding the Select/OK (the round button inside the ring on the remote) for a few seconds?
Hi Rick - Tablo ENGINE does not support closed captioning at this time. Unfortunately I don’t have an ETA to share on when we might be able to include this.
Many of the apps for our hardware DVRs do support this:
