Closed Caption on Gen 4?
I always search the forum before posting a topic. Found all sorts of discussion in 2014 & 2015 about the lack of Closed Caption and then the it being implemented. Obviously this was before the Gen 4 box. I’ve looked at settings and tried down arrows to see if it brought up options like with my Plex tuner. Is there some sort of secret hand shake or something or is Gen 4 lacking Close Captions? Seems like they would have learned in 2014 & 15 the importance of it.
I’m on a 4 tuner Gen 4 running the latest firmware, Roku app running the latest version. I’m too lazy to look up the exact numbers but I checked update status when I couldn’t find Closed Captioning.
Here’s the Support Article: https://support.tablotv.com/hc/en-us/articles/18136635263636-How-to-Enable-Closed-Captions-CC-on-the-4th-Generation-Tablo-App
On Roku, the Tablo just follows the Close Caption setting on the Roku device. I have mine set to Captions on Replay.
Great, that worked. I had forgot that I turned off the CC for the baseball playoffs.
8 posts were merged into an existing topic: Tablo Roku App (4th Gen) Update (v. 1.0.0)
