Chromecast Ultra seems to have solved my worst Tablo problem. 1080 recordings from 1080i broadcasts no longer stall or freeze during playback.
Since Dec 2015 I had been recording at “HD 720p - 5 Mbps (recommended)” to work around these problems. This week I switch to the Chromecast Ultra, and set Tablo recording to “HD 1080 - 10 Mbps, 720@60fps”. None of the streaming issues reappeared; and even some minor stability problems I was having at the 5mbps setting disappeared. Stream startup is fast, stream navigation is trouble-free, and there aren’t any stalls at all. So far it looks rock solid.
Since I have only tested this with a few recordings, I need more time with it to be sure that it really is trouble-free. However, since Google claims it should be able to support 1080p @ 60fps, I suspect the Tablo 1080p @ 30fps bitrate is no longer an issue.
And since I can now record 720p @ 60fps, 720 playback should be about the same as antenna equality now, so that’s great.
Quality of recordings from interlaced broadcasts still doesn’t seem as good as viewing direct from the antenna. 1080i and 480i recordings don’t appear to be quite as clear and brilliant, and objects can be ragged at edges. I’m a bit uncertain about the quality issues. I don’t have any side by side comparison environment. The best I can do is watch a program direct from the antenna, then watch a recording of the same program. I need a lot more time to evaluate this.
In any case, I believe the quality problems with 1080i and 480i recordings are inherent in the current Tablo hardware, and will persist no matter what type of streaming device or player is attached to the Tablo.
TabloSupport NEW Firmware Release - 2.1.18
About deinterlacing
“ … De-interlacing is very computationally intensive. Tablo needs to de-interlace multiple streams of video (and transcode it to H.264) in real time, and at an affordable price. While we use the best chips that are available to us, with current technology it remains possible to see some artifacts under certain circumstances. … We continue to work with our chip vendor to improve de-interlacing performance but we may have to wait for the next generation of silicon to make substantial improvements.”
Be that as it may, Tablo with Chromecast Ultra appears to be very stable, and the user experience is now quite good overall. There are still some quality and functional issues, but no showstoppers. And with all the major issues out of the way and no longer detracting from the overall experience, the slick Tablo user interface on an Android phone or tablet has a chance to shine; it’s really very nice.
I’m not saying it’s perfect. For example, when left paused Chromecast eventually times out, at which point the video resumes on my phone; so when I return I have to figure out where the heck it was when it took off running in my absence. And if I back up from an active Tablo player screen (for example to look at Tablo’s Scheduled Recordings), I have to go find the episode list and resume from there to get back to the player screen; since the notification doesn’t take me to the player screen. On the other hand, if I start doing other things like mail, or put my phone to sleep, Tablo in the background no longer loses control of the stream. All in all, Chromecast Ultra along with the 2016 Tablo releases offer huge improvements over 2015 Tablo.
