I even tried all of this all over again on my upstairs CC thinking the wifi signal might not be as strong on the downstairs one, but same result.
@kgdg1 I sent over a reply asking for your MAC - so send that over when you can.
I’ve had no issues with Chromecast when used via an Android phone to watch a recorded show.
When I use my PC to do the same via the Chrome browser on some shows, not all, but some it’s like it reaches a segment of the show to load and can’t. Always at the EXACT same time in minutes and seconds on a show. If it does it on another show, it will be a different time in the show, but stopping and starting it hits that exact minute and second and buffers forever. This leads me to believe it’s trying to go from one piece of the show to load the next and can’t. For example a show my wife had recorded it got to about 23 minutes and 5 seconds. It hung and buffered. I went back 20 seconds and it reached that spot and did the same. So I dragged the slider around and went to like 23 minutes and 20 seconds and wham - it resumed play fine but if I backed up again and went to like 22 minutes, when it hit 23 and 5, it would hang again. I can’t really blame the Chromecast device for that as if I used the phone it behaved better over the same Chromecast device!
I suspect only Tablo insiders and engineers understand why this happened to me.
The problem that ShadowsPapa reports makes my Tablo useless. Using a TiVo Roamio until this gets fixed.
@winstonmithcell I only just saw this. Is your Tablo buffering/stalling at exact intervals like this?
How do you pair your chrome cast with tablo? I can’t find any instructions for this feature and dine see any way to make this happen so I can’t even watch recorded programs on my tv. Can only watch on my phone.
I believe once you start playback on your phone, there should be a Google Cast icon at the top right of your screen next to the Closed Captioning icon. Hit that, then select your Chromecast.
@Brandon_Stevens - Cash is correct. Start the playback on your phone and then cast it to the TV.
