I cannot connect to my tablo on my desktop. I can connect to it on my laptop. What could the issue be?
To clarify, im referencing a failed connection in google chrome through http://my.tablotv.com/
Do you have a separate modem and separate router?
Is your computer plugged into your mode by chance?
I have a netgear box (modem and router in one box) - so they’re not physically separate. Desktop is plugged into it along with 3 other devices.
The other important question is whether your Tablo is hard wired or wireless?
My tablo is hard wired to my router.
So the Tablo and this desktop are both connected to the yellow Ethernet ports on the back of the Netgear modem/router?
Yes correct
When you cleared your browser cache in Chrome, did you also go to:
Hello - yes i did exactly that. Just tried it again, no dice. Still the same connection countdown endless loop. Running out of ideas here
Have you tried without extensions?
Yes, i have tried disabling adblock, when that did not work i tried disabling all of my extensions at once. Still the same connection issue.
Anyone have any ideas on the issue im having? Dumped in quite a bit of time into figuring this out and it’s pretty aggravating.
Since your laptop can connect to the Tablo, then the Tablo is working fine. The issue then is with how your pc is connected to the network or with the router configuration.
Was not able to ping, seems you’re right in that it is a router setting. All of my settings on the router are defaults. Is there a specific setting which is most likely to be the cause? There are no troubleshooting tools or anything for tablo connectivity, so i’m kinda on my own here.
@themusic246 Try rebooting the router and then trying again. Let us know what the results are like.
Hello. Yes, as mentioned above the tablo and desktop computer are plugged into the same router. It is a router and modem combo box. The link to the modem/router is posted above too. Thanks…
I had this issue when I upgrade my firmware to the .27 beta. The only thing that worked for me was to delete all my browser history and data from the beginning of time in Chrome.
Yes, tried that as well. multiple attempts failed.
Last resort, factory reset the modem/router combo device?
Last last resort, put your modem in bridge mode and buy a new router. The TL-WDR3600 is a great one for the price. See this thread:
http://community.tablotv.com/discussion/1954/remote-connect-works-for-weeks-then-fails#latest
