I can’t figure out how to view my tablo thru my chromecast. I can’t find the wifi looking icon similar to that used on apps like netflix. Any suggestions?
@ctxaggie I am guessing you are looking on the iPad app and it is not available, but it has been asked for.
I’m not seeing an option for sending recorded program to Chromecast on Chrome (on Android smartphone). Any suggestions, or is this feature only for an Android tablet (w/Tablo app) or PC running Chrome only??
How do you watch tablo on a PC? When I go to tablo tv site, I do not see an option to watch or sign in.
I go to my.tablotv.com and it connects and plays just fine (through PC + Chrome browser); but I’m finding that all forms of sending live or recorded video to a Chromecast from Chrome browser doesn’t work at all.
Yes to http://my.tablotv.com/ and no you don’t need to be on the same network as long as you have gone to the Tablo once on your PC. Then you can go outside your network and get to your tablo.
I tried to visit Mytablotv.com but it isn’t a registered domain.
You are right, mytablotv.com is not, my.tablotv.com is, you are missing the period after my
@TabloSupport it appears the issue of casting the video is an issue. Using Chrome on Windows and Mac.
ctxaggie @Jestep Thanks for making us aware of this - our web developer is working on a fix right now! Should be up shortly.
@TabloSupport I assume @matb33 was the guy? I just tried it and it works nicely now!
I have two issues I could use help with. 1st, when casting, the program will freeze periodically. I don’t believe its due to poor OTA reception or the tablo itself. It will freeze when viewing live and recorded programming. I’ve power cycled the tablo, my router, DSL modem, and chrome cast. Then I reset my chrome cast to factor default. Still freezes. I don’t have issues with the router streaming music or netflix through my wifi blu ray player. Is it possible the chrome cast and the router aren’t communicating properly or compatible with one another?
2nd - Recently haven’t been able to cast tablo from my PC chrome browser. I’m receiving “device not available”, but only for the tablo tab, other tabs will cast fine. Don’t have this issue with Android tablet app.
@bkoster I got your ticket this morning - responded with some feedback. Hope you see better results; keep me posted!
Changed the recording setting to Chromecast/Roku 720i option and so far so good no freezes on first test run with it. Thank you for the suggestion! (sorry for doubting that would work
@bkoster No worries. I’m glad to hear that you’re seeing better results
I’m having the same issue described above. My desktop has an ethernet connection to my router. When I open a tab and start casting the show to my chromecast, it works fine for about a minute, then freezes. What did the people above do to fix this?
