Chrome Cannot Open my.tablotv.com
About a couple of months ago my Chrome lost its ability to open my.tablotv.com and shows the message that I need to change https → http, however the ‘s’ is added automatically and I have no way to fix it. Other browsers (Edge) work fine. I guess some settings of Chrome must be modified, please advise if you know which, thanks.
You can take the “s” off and it loads just fine.
Have you tried typing in the full URL yourself?
http://my.tablotv.com/
without just my.tablotv.com and letting Chrome load it however it wants? Most browsers like to default to the “secure” site unless told otherwise.
Once you get the proper page opened, save it as a bookmark somewhere, maybe even in your toolbar. You’ll get to the right place every time with just a single click.
Of course I tried to remove ‘s’, however Chrome restores it automatically. Other browsers (Edge and Firefox) open http://my.tablotv.com/ without a problem, only Chrome enforces https. Probably this is some Chrome’s safety feature activated as a side effect after an update.
Hello. May I ask what device do you have? I have a white 4th gen, and cannot figure out how to use it in a browser or even in the windows app. They said that the white 4th gen does not support this? So I am wondering what device do you have that you were able to make it to work with edge and firefox.
Mine is an obsolete black “Lite” version. It was the cheapest option on sale. Nevertheless I am quite happy with how it works. Concerning your issue, I would start with connecting it to Ethernet (cable) and see if you can ping it. If the thing is dead you should better replace it. In general I like their design, I am an electrical engineer myself.
4th Gen can’t use browser or Windows App at all. Its not a bug, its as designed.
Enter the following in the Google Chrome address bar:
chrome://flags/#unsafely-treat-insecure-origin-as-secure
Enable ‘Insecure origins treated as secure’ feature.
Enter the following inside the feature’s box:
I’ve been using this feature for months.
However, Google Chrome will continue to nag you that you’re using an unsupported flag… and then you can ignore that nag, and click on its X to close it.
Thank you for the advice. I just tried it and it did not work :frowning: Most likely this was not the only update you made while solving the issue :slight_smile:
The support suggested using Firefox in safe mode and it worked. Later I even stopped using the private window and Firefox keeps working fine both with Table streams and pages. I think with all these new safety features Tablo programmers just gave up and dropped web support completely.
Make sure you use:
Don’t click on a link, enter it manually.
I just tried it, and it works.
Yes, I checked, but all I see is neverending “Connecting”. Chrome alsp shows this warning:
try setting #block-insecure-private-network-requests to disabled.
i can open it now, but no sound?
surround sound turned on? turn it off. (or if it’s off, turn it on?)
dunno, the only problems I’ve had with sound related to having surround turned on, and chrome didn’t like it… turned it off, and new recordings (without surround) worked fine… stuff with surround I could still play on the roku, just not from chrome
