This has been happening for a while but since the Android phone app was introduced I use that primarily for managing my Tablo.
The Issue: When I connect to the Tablo using Chrome browser on my laptop, it connects and syncs but the recordings page and scheduled recordings page are always blank. Everything shows up fine on my Galaxy Note 4 native app and on my Roku 3.
I actually did that last week and it worked but the next time I connected on my PC (last night) those pages were blank again. I added a 1 time scheduled recording last night and that showed up on the scheduled recordings page but nothing else showed.
I will try re-seeding again.
Is there anything else I should do when I re-seed? Clear cache, ect?
@TabloSupport, I can install Mozilla and test but before I do all the data shows on my Galaxy Note 4 Android App. Does that give you the same info as trying Mozilla?
The app you’re using on your Note 4 is nearly identical to the http://my.tablotv.com/ portal, so it makes me think there’s something with your Chrome browser causing issues (assuming everything is working well on your Note 4).
We can know for certain by testing with a separate browser on your PC, though.
