My local ABC affiliate which is channel 28 is showing ION channel 66. The channel 66 shows what it is supposed to show. I rebooted and re-added the channels again and still nothing. Any ideas on a fix? Thanks.
Open a ticket and give them your zip code and all relevant information
Try running a fresh channel scan:
If that doesn’t work, try removing that channel, hitting ADD TO GUIDE, and then run a new channel scan and re-add the channel.
That should resolve it, but if not just drop us a note and we’ll get it patched up: www.tablotv.com/ask-tablo/
Ok it worked Tablo, thanks for the fix!
