Hi all!
And now, a new problem. I had connected the Tablo to the internet, with the app finding the device and connecting to it.
@murrelj
I’m having the exact same issue where the tablo cannot start a channel scan.
So… folks on Amazon say the new streaming stick support the new Netflix i/f… however, they also says it’s a bit sluggish. Still wonder why the change hasn’t propagated down (or has it?). Anyone with a Roku 1 or 2 know if you have the new Netflix i/f (if you don’t know, let’s just say, there’s the normal Roku i/f way of doing thing and then there’s the Netflix i/f which doesn’t look like a Roku i/f at all).
I'm having the exact same issue where the tablo cannot start a channel scan.
Is your problem resolved? If not, try a quick press and release of the blue reset button. If that doesn’t correct the problem, recommend that you contact Tablo Support.
Resolved!
It seems that the iOS app on my iPad Air will not start a channel scan. I finally put the app on an Android phone and it worked fine. I can now use the Tablo with all my devices.
I setup my Tablo on an iPad Air and did the channel scan there. Which iOS version are you running?
8.1.1
Yea maybe it has to do with not being up-to-date. I’ll go ahead and install the latest and test that again just to see. Either way, everything else is working on the iPad now that the Tablo is set up.
Edit: no I did just upgrade to 8.1.2 and got the same result:
Error
The channel scan could not be started
Please try again
And then it kicks back to the previous screen.
This is an original (2013) iPad Air running Tablo Software 2.1.20 App 1.2.1(77)
But again, no worries as it works fine after doing setup on an Android phone.
@brentdollins - Do you have location services turned off?
Yes. On and allowed always for the Tablo app.
