Channel receiving limit
I think Tablo restricts the number of channels I receive. When I first relocate my antenna, I get 72 channels. Then, over the next couple of days, that number goes down to about 35 even though I haven’t moved it or changed anything. Then if I try to rescan (when the scan actually works) I never see 72 again.
that doesn’t make any sense unless the software or the Tablo servers are limiting me.
What does “when the scan actually works” mean. I assume you have amplification on. And that you have gone to channelmaster.com broadcast tower map or some site to see what channels you should be getting.
It means almost every time I rescan the Channel LineUp, the app will hang or fail. I either have to reset the app, the device, or both.
iOS
Yes, I have completed your suggestions. Sometimes I amplify; sometimes I don’t.
Hi @Mrliquidaffect,
Our software doesn’t limit the over-the-air channels you get. This is likely a TV reception issue but the behavior you’re describing from a channel scan isn’t normal.
Would you contact Tablo Support? They should be able to help.
